![]() | Home > In Car Electronics (L322) > Cigar lighter fuse |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
front fuse box behind the glove compartment... ... - .- -.
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
Which fuse Stan ?Rear fuse box has cig lighter written on diagram but fuses are OK |
there should be a diagram on the fuse box lid ... ... - .- -.
Yes Stan there is no cig lighter on diagram in glove box only in rear but fuses are ok |
have a look in the WM..i thought it was fuse 52 ... ... - .- -.
The fuses are on the rear fuse board.
Will try relays tomorrow when it is daylight are all these relays interchangeable? Seems to be conflicting reports of which fuse 20amp ? |
@ndfi, i wonder where i got this from then, it shows fuse 52 for the front ciggy lighter..
This is the fuse schedule for 2002-5 cars Stan, not quite sure what you have. |
OK guys got it fuse 1 left hand side of board 20amp put new one in and it blew straight away tried another and now no power to fuse any ideas |
OK it's only just started working again strange but yeah thanks again |
Have a look in each of the sockets- it's not unknown for small coins etc to get in the bottom causing a short to earth. |
Hi thanks for all the help all good now .I can only guess how it blew sounds a bit bizzar but it's the wife's fault for shopping and keeping me waiting for so long.i was getting bored so started playing angry birds on a Nokia 6 whilst plugged in and charging . These phones are relatively new and have a big battery which can have a tendency to overheat which may in turn overheat the charger and blow fuse only overheats when playing games on phone . Also the charging plug with USB has stopped working.new one working fine.there must be a moral here somewhere if not a lesson not to go shopping with the angry bird ,😊 |
