Home > Maintenance & Mods (L322) > Wiper arms into Service Mode?
akk
Hi,
new owner of L322.
Just trying to clean the wiper blades (covered in oil following a lorry!).
Is there way way to get the wiper arms to stay vertical when the engine is switched off so that I can easily reach them both to clean? They always return to the bottom...
thanks
Atul
Post #461626 21st Dec 2017 1:33pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Not sure about the RR, but usually achievable by turning on the ignition & wipers then turning off the ignition just before the wipers get to the top of their sweep. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #461632 21st Dec 2017 2:50pm
akk
Tried that... it's a push button start stop and despite numerous timing attempts, (ala tipping point!) it's failed... engine goes off and wipers still return to the bottom Sad
Post #461633 21st Dec 2017 2:52pm
Pawl
Aagh - the perils of so little driver control with newer models !
With keyless start there is obviously no ignition off that the driver can influence. Paul,
Post #461639 21st Dec 2017 3:12pm
akk
Indeed Laughing
And let's not even start with the rear wiper... that conveniently sneaks into it's little home under the top of the rear window!!! Rolling with laughter
Post #461640 21st Dec 2017 3:15pm
surely it cant be much of a problem to clean the wipers in their normal position? ... - .- -.
Post #461641 21st Dec 2017 3:16pm
[Edit - this applies to the L405 - it was posted in the L405 section & I just noticed the original post says L322 Embarassed and Stan didn't notice Razz ]
For the fronts - on the menu in the middle of the instruments - something like vehicle setup - winter mode will leave the front wipers higher at rest.
For the rear, you need to partially open the tailgate mid-wipe and the wiper will stop in whichever position it's currently in
Post #461642 21st Dec 2017 3:24pm
theres no winter mode on the L322 alistair...
i'm slacking Embarassed ... - .- -.
Post #461643 21st Dec 2017 3:28pm
Laughing
Post #461644 21st Dec 2017 3:30pm
akk
Not much of a problem?
I mist be a 6ft midget then... coz the wiper only comes up about 3 inches, so it's not possible to give the whole blade a clean (only the furthermost 1/3 is possible).
I've contemplated taking the whole blade off it's arm... but that feels like a sledgehammer...
Post #461645 21st Dec 2017 3:32pm
a stool or small step ladder ?
blimey , its a tough day today Rolling Eyes ... - .- -.
Post #461647 21st Dec 2017 3:39pm
akk
haha... I've tried everything... the blade just doesn't come far enough away from the screen to clean... like I said... 2 thirds of it is pretty impossible...
Rolling Eyes
Post #461651 21st Dec 2017 3:57pm
the wiper arm does come away enough to clean it...
Post #461654 21st Dec 2017 4:05pm
I bet you haven’t tried removing them?
Its very easy to slide the slider on the top and simply remove the wiper blade then clean & refit sir Thumbs Up
Sometimes the easiest option is overlooked as a harder task Whistle
Post #461657 21st Dec 2017 4:08pm
akk
lol... I did think about removing it... but was convinced it was a sledgehammer to crack a nut! Laughing
Totally my mistake... I'm not a premiership footballer... so I tend to do my own (routine) maintenance! Rolling with laughter
My son's car (a Seat Ibiza), has a simple mode for leaving wipers vertical... you can then just pull the whole arm back and clean the blade in seconds... no fiddling about removing and refitting etc... oh well... I guess JLR just expect people to pay their service department to do this task for them...good ole JLR... they think of everything!
Whistle
Post #461659 21st Dec 2017 4:21pm
