![]() | Home > Maintenance & Mods (L322) > Faulty steering column - end of the road for my FF? |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
Have a look at this thread which may provide a much cheeper option.
Bagus Member Since: 15 Apr 2014 Location: London Posts: 202 ![]() ![]() ![]() |
You sir, may well have just extended the life of my FF. |
There are several available used examples cheap on Ebay. Maybe worth looking at considering your plans:-
I don't know anyone in Surrey but if you're willing to travel, I would throughly recommend the guys on the link. They're very helpful, have a loan car and their rates are very reasonable.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
Although this deals with the tilt function it will give you an insight into how both work.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 402 ![]() ![]() ![]() |
The in/out function can fail because of 2 main reasons. The black plastic nut can strip its thread or the white plastic motor housing can fail allowing the motor to move freely. The up/down function normally fails because 1 or more of the 4 metal tabs holding the brass nut in place break off.
Thanks for all the replies |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 810 ![]() ![]() ![]() |
good news , my column has never worked in my ownership , I just stuck 12v to the motors and moved it to where I like it |
I guess not moving is better than manually sliding in and out.
ha , indeed it is pal |
Little plastic block arrived yesterday and with the sun shining today I tackled the repair.
Nicely done. Glad it worked out. |
Cheers again Giantlandyman for pointing me in the right direction. |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
@Bagus, Gratulation...... and I am happy to help you in the right moment! Best wishes for 2018 L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
