Home > Maintenance & Mods (L322) > Faulty steering column - end of the road for my FF?
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
Unfortunately two weeks ago my steering column decided to stop retracting. Its fully retracted at the moment but actually can be manually pulled out. I hear the motor run at start up and shut down but something has snapped/given way. The tilt function still works fine.
A quick search on here indicates it might be a replacement column (although I have seen talk of this white plastic clip). A new column seems to be £500 ish on eaby and then there is a few hours labour so guessing no change from £750, probably more like £1k to repair.
A long shot perhaps but can anyone recommend a reliable mechanic in the surrey area to fix? Someone that doesn`t charge dealer prices.
Add to the above, It was due an MOT today so dropped it off and thought I`d try my luck.
failed on the column and also worn ball joints (which I`m not surprised about either).
Its got 96k miles on the clock and has had a lot of money spent on it over recent years but its no garage queen and the cam covers that I had replaced 2 years ago are now leaking again so there`s probably a good £1.5k work at a minimum.
I was planning on upgrading mid next year to a much newer model so not sure I want to throw any more money at it. Might have to sell for parts/repairs and buy a cheap run around for the station commute for 6 months.
Any thoughts/advice appreciated Whistle
Sorry mods if this is in the wrong section Thumbs Up
Post #461339 18th Dec 2017 9:24pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
RE steering column
Have a look at this thread which may provide a much cheeper option.
http://www.fullfatrr.com/forum/topic34124.html
The very last comment/post is the guy who makes and sells the part, I believe.
Post #461351 18th Dec 2017 10:51pm
Bagus
You sir, may well have just extended the life of my FF. Thumbs Up
Those symptoms are exactly the same.
Have messages Uli hoping he has one left in stock (or can make me one).
Thanks
Post #461355 18th Dec 2017 11:15pm
Giantlandyman
RE cam / rocker covers
There are several available used examples cheap on Ebay. Maybe worth looking at considering your plans:-
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0
It might be beneficial to buy new gaskets as well if you go down that route but worth speaking to the garage I recommended (if you intend using them) beforehand.
Post #461364 19th Dec 2017 7:56am
Giantlandyman
RE reliable mechanic
I don't know anyone in Surrey but if you're willing to travel, I would throughly recommend the guys on the link. They're very helpful, have a loan car and their rates are very reasonable.
Mention, Kevin ( 6'4", big build) with the 4.4 TDV8 if you call.
http://redliongarage.com
Post #461366 19th Dec 2017 7:59am
Weegie
Although this deals with the tilt function it will give you an insight into how both work.
http://www.rangerovers.net/repairdetails/s...troduction
I had the tilt problem on my TD6 and removed the cowl under the steering column disconnected the motor and manually put it to the position which suited me and left it there. It may be possible to do the same with the reach function. John
GAP iiD BT
Post #461371 19th Dec 2017 8:22am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
The in/out function can fail because of 2 main reasons. The black plastic nut can strip its thread or the white plastic motor housing can fail allowing the motor to move freely. The up/down function normally fails because 1 or more of the 4 metal tabs holding the brass nut in place break off.
There is a mod to replace the black plastic nut with brass, however, anyone buying a used column should check the state of the 4 tabs and the white plastic motor housing as these are not as easy to fix. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #461380 19th Dec 2017 10:20am
Bagus
Thanks for all the replies Thumbs Up
I have a replacement black plastic nut fro Uli on its way so will have a go at fitting that and will report back.
Post #461432 19th Dec 2017 2:12pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
good news , my column has never worked in my ownership , I just stuck 12v to the motors and moved it to where I like it Thumbs Up
Post #461518 20th Dec 2017 1:20pm
Bagus
I guess not moving is better than manually sliding in and out.
Razz
Post #461519 20th Dec 2017 1:24pm
bembo449
ha , indeed it is pal Razz Razz
Post #461521 20th Dec 2017 1:29pm
Bagus
Little plastic block arrived yesterday and with the sun shining today I tackled the repair.
After lots of swearing, numb fingers and over an hour of faffing around I had finally replaced the block and the telescopic steering column was fully functional again. Thumbs Up
Knowing exactly what to do would make the job quicker 2nd time around should it ever go again.
I needed a longer T20 to remove the centre screw from the lower steering wheel cowl. It was more like 11mm than 75mm as suggested. Fortunately the gap is not that narrow so I could built one around 12mm from my trusty Halfords set and torx bit set.
The hardest part was undoing the 2 allen screws from the bottom of the threaded spindle. I found using a hex bit with a ratchet wrench worked the best to get the bolts loose and then I finished it off with an allen key. Quit tricky to light on the area as well as unscrew. My small inspection torch was often held in my mouth or somehow balanced in my fingers.
It would be a very quick job if you removed the lower dash trim but I figured that in itself would take a while so didn’t consider that a feasible option.
While the console trim was off I also replaced the headgehog resistor and now my fans strength works according to the setting. Have been meaning to do that since summer time when the air con would blow full bore and was too cold...first world problems (I know).
Unfortunately my phone died halfway through but here are a couple of pics of the spindle and the block.
Off to a good start with all 3 trim pieces removed
Hard to see but the Allen screws holding the spindle on are behind the wires.
Spindle with the worn block.
Why they made this from plastic is beyond me. Surprised it lasted this long.
New block carefully threaded on till the spindle reached the end.
Post #462550 28th Dec 2017 11:01pm
Giantlandyman
Nicely done. Glad it worked out.
Post #462594 29th Dec 2017 11:44am
Bagus
Cheers again Giantlandyman for pointing me in the right direction. Thumbs Up
Its nice when a fix doesn't break the bank.
Post #462679 29th Dec 2017 11:18pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
@Bagus, Gratulation...... and I am happy to help you in the right moment! Best wishes for 2018 L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #462804 31st Dec 2017 4:27pm
