Home > Technical (L322) > Couple of embarrassing questions
bigchiefdarkcloud
Malaysia 2010 Range Rover Autobiography 5.0 SC V8 Buckingham Blue
Sorry guys, but can anyone tell me is it okay when waiting at lights to leave it in D with the handbrake on? I used to have a mercedes and this feature was brilliant- I live in a busy city..
Also, how do I connect iphone7 to the hands free??? doesn't seem to want to..
thanks for any help!
Post #461098 16th Dec 2017 11:51pm
Phone, search using your handset for LandRover then the pairing code is 2121 sir Thumbs Up
Best advise for leaving in D with the handbrake on?????? I would think it would up the trans temps! How good or bad that is???
Post #461100 17th Dec 2017 12:18am
mpirie
I guess it depends on how long you are talking about.
Most people keep their foot on the brake with the car in D until it''s time to move.
Even in hilly areas like mine, the autobox will hold the car still on a slope long enough for you to move your foot to the accelerator pedal without it rolling back.
Newer cars have the electonic parking brake which allows for hill start release.
Mike
Post #461124 17th Dec 2017 10:35am
fisha
If its just normal lights with a normal changing period, then yes, its likely to be OK. As already said, lots of people will do effectively the same thing by sitting on the brake pedal at standstill when at lights. If its longer periods like road work lights where you may be waiting minutes, then I take it out of drive and put it in neutral.
Is it going to wear things out in the box ... not really unless you do it for ages. ... but it will eat fuel quicker. When in drive, the gearbox is trying to push the car forward at crawl speed, and the engine is supplying that demand. Yes, the engine stays at idle speed, but it'll be working to keep it at idle as its pushing against the brake just maintain idle revs. Putting it in N or P will take that demand off the engine and it'll use less fuel.
Generally ... my rule of thumb is that if I'm stopping long enough to get bored of pressing the brake and putting the handbrake on, then i'll also put it in neutral as well.
It takes a fraction of a second to flick it back into drive and pull away. the handbrake will auto release when you pull away as well. V8 or else ...
Post #461130 17th Dec 2017 11:28am
CS
I think the handbook says that one should not sit with the car in drive and the brake on for extended periods, you might like to check. I always put it into neutral and the handbrake on, finding that it is not much effort, also in the dark one does not dazzle the driver behind with the brake lights that way. Only Range Rovers since 1988
Post #461175 17th Dec 2017 6:58pm
bebechoon
France
As regards the debate leave in drive / put in neutral, this has been discussed before. You may perhaps find this of interest:
http://www.fullfatrr.com/forum/topic37680....=automatic
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #461176 17th Dec 2017 7:04pm
p38arover
Australia
Leave it in Drive. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #461198 17th Dec 2017 9:34pm
