Home > Technical (L322) > Heated Seat Problem - 2007 TDV8 Vogue SE |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 |
How difficult is it to get the seats out and dismantle them? Jordan
7th Feb 2017 10:12am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Very easy, there is a very good guide if you use the search function 2015 4.4 AB
7th Feb 2017 10:59am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Just had our driver side unit fail, same problem with the split pipe but unfortunately the peltier unit had failed as well probably due to the lack of air flow. SDD showed the seat base temperature shoot up, but the seat back remained static and then the whole system shut down. Fans ran for cooling, but SDD didn't show a temperature drop.
1st Apr 2017 7:28pm |
tomo_ Member Since: 24 Jul 2015 Location: PL Posts: 9 |
Just went through the adventure with mine. Fixed air duct, but pletier failed too. High resistance instead of some ohms.
25th Sep 2017 4:33pm |
So possibly found reason for broken ducting.
6th Oct 2017 11:21am |
Greggiii Member Since: 22 Sep 2017 Location: SW Posts: 5 |
Hey guys. Driver seat issue here.
21st Oct 2017 7:07am |
MrChubba Member Since: 03 Dec 2017 Location: Penrith, Cumbria Posts: 4 |
Very new to this site and I have recently purchased a 2008 Vogue SE and amongst other things the Drivers Heated seat isn't working. I've read on here and various other forums that its likely to be the plastic pipe in the back of the seat or, the pletier. Does anyone have part numbers for these items? As suggested, if I am to remove the seat etc... I amy as well have the part to hand. However, I do not know what I am buying.
3rd Dec 2017 9:57pm |
dutchhome Member Since: 26 Feb 2016 Location: Delaware, USA Posts: 13 |
I apparently have this cracked air duct problem. Both sides of the duct have cracked open and I don't fancy my chances of taping it up. Has anyone found a replacement air duct that doesn't include the motor? Even at wholesale prices the motor is nearly $300. |
15th Dec 2017 12:36am |
Hi Steve, there are probably better places to look up parts but I use parts.com. I would give you the part numbers for my L322, but I don't know if the Vogue uses the same parts. Just go to the web site and enter your vehicle info and browse parts until you get to the individual seat components (Body Hardware -> Seats and Tracks -> Front Seat Components). Then just click on the diagrams and look for the parts you need. Alternatively you can just call your local dealer. If I'm lazy or can't find a part I'm looking for I'll call the dealer and ask for their parts dept. |
15th Dec 2017 12:43am |
Never mind, it seems gaffer tape really does work wonders. I'm not sure how long it will last, but I'm sure it'll survive the winter. |
15th Dec 2017 3:34am |
tj2k Member Since: 10 Dec 2017 Location: Shropshire Posts: 34 |
See here:
1st Jan 2018 5:53pm |
