![]() | Home > Technical (L322) > Heated Seat Problem - 2007 TDV8 Vogue SE |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
How difficult is it to get the seats out and dismantle them? Jordan
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Very easy, there is a very good guide if you use the search function 2015 4.4 AB
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Just had our driver side unit fail, same problem with the split pipe but unfortunately the peltier unit had failed as well probably due to the lack of air flow. SDD showed the seat base temperature shoot up, but the seat back remained static and then the whole system shut down. Fans ran for cooling, but SDD didn't show a temperature drop.
tomo_ Member Since: 24 Jul 2015 Location: PL Posts: 9 ![]() ![]() |
Just went through the adventure with mine. Fixed air duct, but pletier failed too. High resistance instead of some ohms.
So possibly found reason for broken ducting.
https://lh3.googleusercontent.com/aoZaJhHy...91-h220-no as wrote mine failed and pletier too. Got second hand working replacement but to avoid issue again I did small improvement by bending upper part of the metal frame and giving something like +1cm space. So if one sits in this configuration there is still few mm room.
https://lh3.googleusercontent.com/WNyrIjFV...72-h941-no you can see bend element. It can be used preventive - if you tend to push back into the seat , you can consider doing it before your ducting breaks. Did mine with seats in-situ. |
Greggiii Member Since: 22 Sep 2017 Location: SW Posts: 5 ![]() ![]() ![]() |
Hey guys. Driver seat issue here.
MrChubba Member Since: 03 Dec 2017 Location: Penrith, Cumbria Posts: 4 ![]() ![]() ![]() |
Very new to this site and I have recently purchased a 2008 Vogue SE and amongst other things the Drivers Heated seat isn't working. I've read on here and various other forums that its likely to be the plastic pipe in the back of the seat or, the pletier. Does anyone have part numbers for these items? As suggested, if I am to remove the seat etc... I amy as well have the part to hand. However, I do not know what I am buying.
dutchhome Member Since: 26 Feb 2016 Location: Delaware, USA Posts: 13 ![]() ![]() ![]() |
I apparently have this cracked air duct problem. Both sides of the duct have cracked open and I don't fancy my chances of taping it up. Has anyone found a replacement air duct that doesn't include the motor? Even at wholesale prices the motor is nearly $300. |
Hi Steve, there are probably better places to look up parts but I use parts.com. I would give you the part numbers for my L322, but I don't know if the Vogue uses the same parts. Just go to the web site and enter your vehicle info and browse parts until you get to the individual seat components (Body Hardware -> Seats and Tracks -> Front Seat Components). Then just click on the diagrams and look for the parts you need. Alternatively you can just call your local dealer. If I'm lazy or can't find a part I'm looking for I'll call the dealer and ask for their parts dept. |
Never mind, it seems gaffer tape really does work wonders. I'm not sure how long it will last, but I'm sure it'll survive the winter. |
tj2k Member Since: 10 Dec 2017 Location: Shropshire Posts: 34 ![]() ![]() ![]() |
See here:
