Home > Technical (L322) > Terrain Response Selection
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Hi,
Sorry if this seems a dumb question, Ive looked in my owners manual but couldnt find anything and have searched on here.
My question is..........Can, for example the Mud. Snow and Gravel setting be selected while on the move, and at what speed is best ??.
Thanks
Post #460518 12th Dec 2017 11:31am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I have changed the Terrain Response selection on the move at less than 10 MPH. It's the Low/ High Ratio change that can only be done stopped in Neutral, I believe.
Post #460519 12th Dec 2017 11:35am
j_rov
The manual doesnt say you cant do it on the move, so I would think you can.
The vehicle will warn you if it can't complete the action (for example needs low range for the mode yet you are in high range)
I have switched between normal and GGS this week on the move, but all below 10mph. Throttle response changes after a second or two. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #460526 12th Dec 2017 12:01pm
Strider
Thanks everyone,
I used it for the first time yesterday, I did stop and selected it, I noticed a distinct difference in engine pick up and brake feel and a big plus of course "no bongs of death".
There is very little traffic where i live and the snow tends to get very deep with ruts and is slow to melt away so I thought i would give it a try, very impressed Thumbs Up.
Post #460588 12th Dec 2017 4:20pm
j_rov
It's quite remarkable isn't it! HDC down steep icy roads is very clever too. You do have to trust the tech though... __
Land Rover History:
1976 Series 3 2.25
Post #460591 12th Dec 2017 4:28pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
I was wondering about HDC in snow / ice.
If you're in snow mode, I presume the FFRR's brain knows and acts accordingly. What do I put here then?
Post #460594 12th Dec 2017 4:36pm
j_rov
Yes, I was in Grass Gravel Snow with HDC pressed and in High Range. I was then able to control my descent using the cruise control buttons. Amazing how the gizmos can slow such a heavy car on ice.
Obviously physics will always prevail and if you are simply too fast or there is zero grip, gravity will beat the gadgets. __
Land Rover History:
1976 Series 3 2.25
Post #460595 12th Dec 2017 4:50pm
GAC23
Thanks.
Shame all the snow's gone from round me ...
... I'm itching to give it a go now. What do I put here then?
Post #460597 12th Dec 2017 4:55pm
andygts
Yes you can select any while on the move, you can also switch between hi + lo range while moving BUT you have to coast and select neutral while doing so. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #460678 13th Dec 2017 1:19am
I’ve been using the “grass,gravel and snow” and HDC quite a lot over the past couple of weeks. You can engage it on the move and it’s excellent.
One thing I have noticed is that, having put the dial back to the normal position and getting the “special programmes turned off” message”, I switch the car off, only to find the next morning that the thing has gone back to the previous setting. It’s happened a few times now and I don’t know why. Got - 2017 SDV8 Autobiography in Loire Blue
Post #465493 22nd Jan 2018 1:05am
Roadking
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I went out for a good play with he car yesterday in fresh snow over ice. I wanted to try the technology when I didn't really need to go anywhere and could walk home if needs be. The car was truly impressive.HDC was excellent and it romped up a fairly steep and technical (steep sharp turns) hill back to the house. Photo shows the last drag to the top which is steeper than it looks. All this on road tyres (with not much life left in them)
I love this car!
Post #465564 22nd Jan 2018 2:32pm
