![]() | Home > Technical (L322) > Terrain Response Selection |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
I have changed the Terrain Response selection on the move at less than 10 MPH. It's the Low/ High Ratio change that can only be done stopped in Neutral, I believe. |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
The manual doesnt say you cant do it on the move, so I would think you can.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 507 ![]() ![]() ![]() |
Thanks everyone,
It's quite remarkable isn't it! HDC down steep icy roads is very clever too. You do have to trust the tech though... __
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
I was wondering about HDC in snow / ice.
Yes, I was in Grass Gravel Snow with HDC pressed and in High Range. I was then able to control my descent using the cruise control buttons. Amazing how the gizmos can slow such a heavy car on ice.
Thanks.
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 364 ![]() ![]() |
Yes you can select any while on the move, you can also switch between hi + lo range while moving BUT you have to coast and select neutral while doing so. Current
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6777 ![]() ![]() ![]() |
I’ve been using the “grass,gravel and snow” and HDC quite a lot over the past couple of weeks. You can engage it on the move and it’s excellent.
Roadking Member Since: 03 Sep 2017 Location: West of Scotland Posts: 38 ![]() ![]() ![]() |
