Home > Technical (L322) > 2011 headlight swap |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Can the lens not be swapped over. I'm assuming the lens is the same. Some folks split them open to fit halo DRL's inside so they do come apart.
12th Dec 2017 1:02am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
You cannot swap the lenses as they are glue’d with an unusual type of glue that does not allow the “usual” heat & removal...
12th Dec 2017 2:05am |
Mate, for the money I'd save I'd be getting the air driven disc cutter out with a 1mm disc.
12th Dec 2017 2:56am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 739 |
Thanks Gents
12th Dec 2017 8:38am |
Have you tried looking for a used one. Problem with a new light on one side is it will be very noticeable. Something that would irritate me.
12th Dec 2017 12:44pm |
