Home > Technical (L322) > 2011 headlight swap
cass
2011 headlight swap
Has anyone replaced an adaptive headlight with a non adaptive one on a 2011 car?
I’ve smashed the lens on one of mine and have found a new none adaptive lamp costs a good bit less than the adaptive one but I’m not sure that it would work OK
Any ideas?
Thanks
Post #460452 12th Dec 2017 12:28am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Can the lens not be swapped over. I'm assuming the lens is the same. Some folks split them open to fit halo DRL's inside so they do come apart.
Had a Jag XK with adaptive lights, one stone and £1400 lighter Big Cry
See if you can get the broken lens off first and if it's a no go you've lost nothing 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #460455 12th Dec 2017 1:02am
You cannot swap the lenses as they are glue’d with an unusual type of glue that does not allow the “usual” heat & removal...
You can use the “non” AFS lamp and simply have the “AFS” facility switched off in the cars CCF file. You need an appropriate diagnostic tool for this (the IID tool) for example... Thumbs Up Otherwise you will have a yellow headlamp fault light displayed on the dash... Thumbs Up
Post #460456 12th Dec 2017 2:05am
Grofus
Mate, for the money I'd save I'd be getting the air driven disc cutter out with a 1mm disc.
A bit of patience and clear epoxy and it would be done. To bin a hugely expensive headlight for broken lens is just wrong.
Just my thoughts 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #460457 12th Dec 2017 2:56am
cass
Thanks Gents
Craig - that’s the exact info I needed, much appreciated. I just have to decide if AFS is worth £250 on top of the £800 for a new light!!
Grofus - Unfortunately the lens isn’t available separately so fixing it isn’t an option
Cheers
Post #460475 12th Dec 2017 8:38am
Grofus
Have you tried looking for a used one. Problem with a new light on one side is it will be very noticeable. Something that would irritate me.
Hope get it sorted. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #460531 12th Dec 2017 12:44pm
