![]() | Home > Wheels & Tyres > Tyre Sizes Question 255/50/20 vs 275/45/20 |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
I guess it depends what sort of driving you are doing. Wider tyres in winter usually makes the grip worse on snow and slush. I run 255 55 20 which have a slightly higher profile giving more comfort than the original 255 50 20 spec are good in general and snow conditions whilst also being insanely cheap (Pirelli Verdes). Tom
Bought my car with 275's. When I switched to my winter tyres, which are 255's, I noticed a quieter, more comfortable ride. I didn't notice anything much lost in grip, but I drive it for comfort, not for speed! |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
275 45 are range rover sport sizes. People run them when they fit sport wheels / tyres as that's what they come with.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35667 ![]() ![]() |
275 40 20 are RRS tyre size not '45'... ... - .- -.
Oops, my bad.
RuthlessGK Member Since: 28 Oct 2015 Location: Sheffield Posts: 83 ![]() ![]() ![]() |
I was just wondering. I just wasnt sure whether there was any specific reason. I just checked I have Goodyear Eagle F1 in the garage and Nexen Roadians on it at the moment. The Nexens are 255/50/20 and the Goodyears are 255/55/20 which is fine either way.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3788 ![]() ![]() |
In my experience 275/45/20 is the size the L322 should have always had. It's virtually the same rolling radius as 255/50/20, looks far better, handles better on road, rides better and gives more protection to the rims.
Might be an option for me when mine need replacing then.
bob-lad Member Since: 12 Jun 2015 Location: Herefordshire Posts: 92 ![]() ![]() ![]() |
The 275/45 may handle better in the dry, but as mentioned earlier will be significantly worse is snow or slush and as with all wider tyres more prone to aquaplaning.
Not quite correct. The 275 gives far more rim protection as it is 20mm wider, i.e. 10mm either side.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Just fitted some 255/50 20 verde scorps to mine.
That depends whether you're protecting the rims from pot holes/ rocks or an inability to park next to the kerb
