![]() | Home > Technical (L405) > Sluggish / very flat pick up from standstill |
luciogodoy Member Since: 08 Nov 2017 Location: Winchester Posts: 10 ![]() ![]() |
Hi
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 680 ![]() ![]() ![]() |
Surely it’s covered by warrranty ??? |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Yes it is under warranty but I don’t work like that. I always like to have an idea of what it can be before I have to deal with the BS dealerships give. I have lost count of the number of times I have gone to them with problems and their response is “can’t find any fault sir ....computer says no” |
Fair enough , luckily I have a local dealer that is pretty trustworthy and likes to please which I know is rare. |
Couldn’t agree more! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
It might just be worth checking that one of the rear brake calipers is not sticking?
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Are rear calipers on 405s prone to sticking. Just asking as had to replace both on mine just at 86k? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 ![]() ![]() |
Could it be anything to do with the Auto Terrain Response starting off in Snow/Ice mode due to low ambient temperatures at the moment? |
Plugged in my GAP tool - no error codes reported.
well, well well
It is daft that the dash doesn't display the mode the Auto Terrain Response has selected for you. You can only tell if you switch it out of auto and then find what mode you are in. It is also a little basic to change the throttle map purely because of a low ambient temperature. It would make sense to only do this once the traction control senses loss of traction combined with a lower temperature. |
