![]() | Home > Technical (L405) > L405 replacement windscreen |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
Might sound like an odd question - but is the wiper warming area connected ?
dfulgo Member Since: 16 May 2015 Location: Milan Posts: 70 ![]() ![]() |
... good question. The guy told me that the connector for the heated windscreen is identical to the previous, but the separate one for the wipers rest area is totally missing on the new one.
You can check your car - or he can - the connections are in the bottom side corners - so you need to remove the trim from the pillar next to the windscreen - there's an Air Bag plastic sign that flips out and there's a screw behind it - then the pillar cover just lifts out. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1464 ![]() ![]() ![]() |
My Screen took Five attempts to the get the right screen and a Genuine JLR one, got there in the end never heard of bits being discontinued of the screen, i know the later ones are slightly different with regards to connections for heating elements, dont forget various sensors need re calibrating, so make sure thats done properly
Ours was fitted perfectly well (a pleasant surprise).
