![]() | Home > Maintenance & Mods (L322) > How to lube the blower motor in less than a day? |
Dashboard, head unit and face vents off, you should then have sufficient access, less than an hour each way |
d00d Member Since: 11 Jan 2016 Location: Pacific Northwest, USA Posts: 55 ![]() ![]() |
Thanks Joe!
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Why not get everything open and running to gain the access you need then simply disconnect the battery, stopping the motor and not allowing the baffles to close! |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
Getting access to the fan is a pain, but even if you can see it, the bearings that will be causing the noise are hidden by the pressed steel bearing mounts.
If anyone is waiting for the final outcome here I did go under the hood, pull the filter, and find that the fan is visible to the naked eye, and exploration by borescope shows that if a long enough flexible oil tube could be snaked between the vanes at the top then it should be possible to dribble some lube down the back to the shaft. (We assume that even sealed bearings must be knackered enough at this point that some lube should work in via capillary action. Yeah, uhuh, for sure!) |
