Home > In Car Electronics (L322) > Phone pairing
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Phone pairing
My Samsung phone pairs to the fatty via bluetooth OK but every time I turn off the car or go out of range I'm having to re-enter the PIN to reconnect.
On my other Fatty it just pairs and reconnects without having re-enter the PIN every time.
Is there some setting I need to change as it gets tedious to the point where I don't bother which, of course, defeats the purpose.
Any ideas? 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #459135 1st Dec 2017 4:48am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
It is probably down to the firmware on the Bluetooth module, there are a few folks who can upgrade the firmware. One such is bluetoothexchange.co.uk
Post #459138 1st Dec 2017 7:04am
Grofus
Ah, OK. That makes sense. I just assumed they would be the same.
Thanks for the help 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #459189 1st Dec 2017 2:21pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I had the same issue with mine, reflashing the BT module with my IID tool solved it.
Post #459555 4th Dec 2017 2:25pm
Grofus
Did you re-flash the firmware as suggested above. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #459556 4th Dec 2017 2:31pm
hamlet
I'm not sure if it actually upgraded the firmware, I just flashed it myself with my IID tool and a laptop and now it connects automatically and I think the phonebook shows too.
Post #459564 4th Dec 2017 4:27pm
Grofus
Ok cool, I'll look into it
Thanks. Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #459612 4th Dec 2017 9:37pm
p38arover
Australia
Reflash? What did you do with the IIDTool? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #459619 4th Dec 2017 9:54pm
Weegie
In the GAP user manual 4.11.4 page 158 https://www.gap-diagnostic.com/support/documents/IIDTool/ John
GAP iiD BT
Post #459641 5th Dec 2017 6:54am
Grofus
OK , got the phone issue sorted with an exchange module from Bluetooth Exchange.
Excellent service from them, worked first time and less than 5 mins to fit.
Got all my contacts loaded up and no more messing with pin numbers.
Jump in, turn on and it's paired. Thumbs Up It's the little things that make the day.
Thanks to Jamiehol for tip. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #460388 11th Dec 2017 5:25pm
