Home > Technical (L322) > Highest mileage 4.4 m62 without guide replacement? |
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 134 |
I don't think nicksaab has done his and he's pushing 200k miles!
29th Nov 2017 6:08pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3142 |
I had mine done at 188,000. |
29th Nov 2017 10:20pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Is yours LPG Converted ?
29th Nov 2017 11:11pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
It is but how would that make a difference I have had the low temperature thermostat conversion on there for 20k miles im guessing that helps protect it. Do you change the chains as well as I’m guessing they stretch? Current stable:
30th Nov 2017 7:42am |
over here as well then, i was asking dolphinboy if he has LPG as he did his at 188K, i don't know why but i read somewhere, my timing chain guides at 120k ish were perfect and my chains were exactly the same length as the new ones but i dont have LPG.
30th Nov 2017 8:25pm |
@andy/Holiday chicken,
30th Nov 2017 10:09pm |
I've seen them with much lower miles than 188K with the guides gone and mine were fine at 120k. it could be lpg influence or maybe oil type or maybe just the luck of the draw and differences in the plastic used, quality or even a variation within the same spec. i think whatever happens they will go one day for sure if the rest of the common faults don't bankrupt the owner into scrapping it for spares before they get chance to ruin your day |
1st Dec 2017 12:35am |
