Home > Technical (L322) > Testing speed sensors.
Chasazim
Australia 2004 Range Rover Vogue 4.4 V8 Epsom Green
Hello again, still having problems with suspension, Patrick at Gap helped me through elimination of possible causes, now i am checking wiring and sensors befor looking at the ECU.
I removed sensors and cleaned them,(not very dirty and not stuck in the hub) all well,so with them on the bench i check them using a multitester with diode testing ability, here comes the good part, all 4 show no resistance so are they us? What are the chances, so i went out and bought another multitester just in case,. No luck, but when i refit them i have speedo ,and sometimes cruise control, checking from the plug on the ABS ECU, they are all Censored or am i doing something wrong? Shocked please help. Big Cry
Post #457898 20th Nov 2017 3:11am
Some youtubes links
https://www.youtube.com/results?search_que...eed+sensor
You should be getting resistance back on the sensors if they are OK, so seems odd that all four are not giving a reading??
Also check the toothed rings on the halfshafts for dirt, corrosion or deterioration.
Ensure that the sensors are as close as possible to the rings without touching when fitted. .
Post #457906 20th Nov 2017 9:10am
Chasazim
Thanks for the information Joe, i have watched several of those videos to make sure i was on the right track, i first tried to check the sensors through the main plug on the ABS ECU and then i tried each sensor to eliminate the possibility of a damaged or broken wire, so i will get a known good sensor and see what is what.cheers.
Post #457915 20th Nov 2017 11:07am
Chasazim
Well i am back again Cool the problem persists, when checking the sensors i get conflicting results, having watched several tutorials on how to test the sensors i removed them and set about testing, the results were all fail Shocked so i went out and bought another tester. No difference,
When i fault check with my iid tool i get right rear open circuit , the wiring looks good. So i bought another new rear sensor to check if my testing is correct, new sensor failed so now i am even deeper in the dark Confused
On the videos i watched the tester showed a number as the resistance, with my testing, with the positive and neg.on one way i get a 1 reading, reverse polarity and i get a 1 but with a brief flash of a four digit number, and each time it is different
I am beginning to fear it is the ECU and instead of throwing money away i better save up for a new one Big Cry
Is it possible to have it repaired? And does anyone have any recomendation. Thanks for your help.
Post #458987 30th Nov 2017 3:25am
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Hi did you ever resolve the problem , you had measuring the resistances .
I have just fitted 3 new sensors .The forth showed open circuit compared to the other two I tested which had a resistance, I have taken it back to L/r , now thinking did I try swapping polarities to check . Would be interested to know how you got on , I know it was some time ago , perhaps someone can help me here . L/R haven’t got back to me yet, well the dealer hasn’t.
Post #489815 24th Sep 2018 11:46am
