Home > Technical (L322) > FBH error codes
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
FBH error codes
It's easy to see that it is getting colder by the amount of FBH threads. I have not been able to find the answer for this though.
I started it manually just now, it started humming and i could feel the exhaust was warm. It ran for a few minutes then stopped. I hooked up my IIDtool and for FBH I found 2 error codes. I have tried Google, I have tried this forum, but I can not find anything about these codes:
1/2 0x0B08re Unknown
2/2 0x0204re Unknown
Can anybody help me to dechifre these two? 2006 Supercharged
Post #458678 27th Nov 2017 2:08pm
Ian928
Did some more testing:
Test 1
Removed and reinstalled fuse
Started park heat maually and timed it
FrenchMike mention "weird turbine like noise", this is definately true when it starts up
The fuel pump ticks at least two times pr sec
It stopped after 3min 57 sec. I see that FrenchMike states that stop after 4min 10sek is a sign of bad glow plug resistor. Maybe this is the problem?
Test 2
Reset errors in ECU with IIDtool
Started park heat manually and ran till it stopped (did not time it)
Checked errors with IIdtool, now only one error code: 0x0204re
Test 3
Started the car (-2�C outside and the enginge showed cold) and listened for the FBH and felt the exhaust
I could not hear or feel it start. Does the FBH not act as a extra heater for the Petrol models? 2006 Supercharged
Post #458683 27th Nov 2017 3:08pm
Sandyt
The glow plug issue won't apply as it is petrol and the heater runs off the main tank I ended up having mine replaced under warranty so can't help much afraid but it sounds like a fuelling issue
Post #458701 27th Nov 2017 7:10pm
nino_nino
was the engine running Ian? if not it may be the battery is to weak.
Post #458716 27th Nov 2017 8:32pm
Ian928
Of course no glow plug! But maybe the controller is checking something with the spark plug at the same point in the sequence? 2006 Supercharged
Post #458764 28th Nov 2017 9:04am
Ian928
No, the engine was not running. I do not think the FBH even tries to start when the engine runs, I am not sure if this is correct or not.
I am pretty sure my battery is ok, but I will try to put a trickle charger on it.
Really interested in the error code I am getting! 2006 Supercharged
Post #458770 28th Nov 2017 9:29am
Ian928
Did some more tests today:
Put a very inaccurate voltmeter across the battery. It read 11,7V. Started the FBH manually and the voltage dropped to 11,5 and stayed there. The FBH ran for over 5 minutes, then I heard the fan (or circulatin pump?) rpms starting to change up and down, it could very well be that the FBH was cutting in and out because of undervoltage, but I could see no change from the voltmeter.
I then put a tricle charger on for a few minutes and tried again. Before starting the FBH the voltage now was 12,1V, but as soon as the FBH started it fell to 11,6V and stayed there. The same thing happened, after some minutes the stuttering sound came back.
I do think I changed the battery lasty year after unsuccessfully tyring to run the FBH, that did not make any difference. 2006 Supercharged
Post #459180 1st Dec 2017 1:07pm
nino_nino
Ian928, on mine it runs with the engine running. it helps engine to get to working temp. and the bonus is faster heat in the cabin. start the engine and listen for the pump clicks and the humming from the heater.
Post #459197 1st Dec 2017 5:29pm
Sandyt
The petrol ones only cut in with the engine running if the temp is below 1degree c on the oil burners I think it is 14 or 16 degrees c so quite different
Post #459247 1st Dec 2017 11:11pm
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
My 2004 TD6 is the same. On cold mornings the FBH will fire up with the engine running to aid rapid warm up of the engine & cabin. Late 2004 FFRR Vogue 3.0 TD6 Tonga Green
Previous cars
Series 3 V8 conversion
1989 V8 classic Vogue
1992 V8 Classic Vogue
1998 P38 DSE
Post #459258 2nd Dec 2017 2:33am
Ian928
I have now received a description from GAP about the code:
Combustion air fan - Open circuit or short circuit to battery
So does this mean for sure the fan motor is faulty, or could this be a problem with the controller? I have read a lot about faulty controllers on this board. 2006 Supercharged
Post #461343 18th Dec 2017 10:52pm
