Home > Technical (L322) > Is this ticking noise normal?
GGDR
Did I see Edd China using some kind of stethoscope once to trace a noise?
Did they do the idler pulleys under warranty?
Greg Cheers, Greg
Post #458568 26th Nov 2017 12:45pm
Paul thornton
Non of those symptoms are very good or cheap to repair.
I hope your warranty covers it especially as it sounds like whoever serviced it last has caused the issue.
Post #458573 26th Nov 2017 1:08pm
OtleyDominic
Millennium range rover specialists Surrey last serviced it and look to be the ones who put the oil in and overfilled it, assuming no one touched it since, of which I can not see they have from my records.
Given I only bought it two weeks ago, it has a three month warranty and I have a right to refund currently
Post #458581 26th Nov 2017 2:28pm
jeff88
France 2011 Range Rover Vogue TDV8 Ipanema Sand
hello,
is it somme oïl on accessory belt ?
on one side or two side of accessory belt can you see somme string?
you can test with water on the belt, if the noise stops it is a wrong alignement. if a roller (or the four) is defect, the belt is worn on one or two side. change all roller and tensionner and belt.
To know if the oil is diluted with diesel, you can do a stain test.
A drop of oil on a paper. There should be no halo around the oil stain after two hours
by
jf
Post #458720 27th Nov 2017 8:40pm
OtleyDominic
Thank you, I will bear that in mind and see how the garage replies
Post #458858 28th Nov 2017 8:29pm
Nope not right, doesn’t sound pulley or belt related to me.
No idea what it is, but it sounds more top end tapperty noise to me. I would be round that with a listening rod and try to isolate roughly where the noise is coming from.
Personally I would send it back and get a different one. There is nothing that can't be fixed with a hammer😜😜
Post #458866 28th Nov 2017 8:56pm
OtleyDominic
The cause of the issue is still unknown and the garage have taken the car back and agreed a replacement. They have since swapped the fuel pump and it made no difference.
Post #459881 6th Dec 2017 9:30pm
Paul thornton
Well there's a strong argument for buying from a reputable dealer.
Hope all goes well.
Post #459887 6th Dec 2017 10:08pm
wack61
That's not a ticking noise, THIS is a ticking noise
http://www.fullfatrr.com/forum/topic45486.html
Post #459897 6th Dec 2017 10:56pm
OtleyDominic
That's not ticking, that is proper knocking Smile
Post #459954 7th Dec 2017 6:02pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Noise stays without belt? Was engine running without belt with the same noise? Best rgs L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #459958 7th Dec 2017 6:28pm
OtleyDominic
I have a replacement car from the garage. They tried the fuel pump, tensioners and oil change but noise still there apparently. LR believe it is warn tappets, but who knows!
Post #460464 12th Dec 2017 8:06am
BenRK
I appreciate this is a very old thread, however does anyone know whether the original videos are still accessible somehow? I'm really keen to see whether this noise is the same as what I have. Thanks
Post #591141 13th Apr 2021 10:17pm
OtleyDominic
If you message me, I will try and dig it out
Post #591146 13th Apr 2021 10:43pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Was the cause ever determined?
Ours ticks when warm, and apparently it’s normal. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #591239 14th Apr 2021 6:10pm
