Home > Technical (L322) > Humming/Vibrating/Wind Noise above 55mph...
Rich_Allen
Evening all...
Have done a little searching and seems to be trim issue...
Yesterday I had both headlights out for bulb change, since then when I get to around 55mph I am getting a really annoying humming noise from what seems the near side of the windscreen.
It is not always there, sometimes it is fine but it seems to happen more often than not. Never heard it before yesterday..
A few threads state it’s the scuttle panel below the windscreen (so completely unrelated to bulb changes)
Scuttle panel seems tight and snug...
Where should I apply tape to try and rule out certain bits and any recommendation for type of tape?
Driving me nuts!!!
Thanks 2008 TDV8 Vogue SE
2002 TD6 Vogue
2002 Defender 90 TD5
2002 Range Rover P38 Autobiography
2002 Range Rover P38 Westminster
Just a sucker for big bills!!!
Post #458256 22nd Nov 2017 8:06pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Masking tape works (not the low tack type) but DO NOT LEAVE ON OVERNIGHT. If it gets wet or damp then dries it's a right game to get off.
Post #458259 22nd Nov 2017 8:37pm
Lee Marsh
England 2006 Range Rover Vogue Td6 Zambezi Silver
Mine has developed a humming/vibrating noise over 50 mph, since scuttle was removed to access windscreen wiper mechanism.
Bought some clear Evo silicon type adhesive the other day, (some not recommended for soft plastic/rubber surfaces). Plan to give it a clean and run a seal to hopefully reseal the rubber strip at the bottom of windscreen
Post #458363 23rd Nov 2017 8:48pm
miggit
The scuttle panel is the normal cause at that sort of speed, air under the bonnet comes up underneath the scuttle and cause the vibration.
When the windscreen is replaced the scuttle panel is glued (thin bead) to the windscreen to stop this happening, the correct glue to use is polyurethane flexible adhesive / sealer, but it should really be the fast drying version that the windscreen boys use, but forget that as it's an arm and a leg and the slow drying stuff is just as good!!
This is about the cheapest stuff that I could find http://www.ebay.co.uk/itm/HIGH-STRENGHT-PO...OZBRikIvug Yesterday I couldn't spell Engineer... Today I are one!
Post #458383 24th Nov 2017 12:30am
