Home > Technical (L322) > One headlight is looking at the floor. |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
It's possible the arm that connects the leveling motor to the reflector has detached.
20th Nov 2017 9:13am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
^Or failing that ^ (which is a good shout )
20th Nov 2017 9:42am |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 164 |
Thanks for the advice, yes the lights test ok and were cornering ok just o/s pointing at the floor. Took the head light out could not see any motors or links through the big hole at the back.
20th Nov 2017 11:11am |
The same as you would adjust the light for an MOT etc... Allen key on the top from memory
20th Nov 2017 11:21am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
that image is for normal headlight adjustment craig, noworries has an AFS system so it sounds like the vertical stepper motor has failed ..
20th Nov 2017 11:36am |
I was going to suggest that the headlight adjusters adjust the whole head light assy not just single eye part. Going to look at the wiki section Thanks If everything is under control you are not going fast enough.
20th Nov 2017 12:56pm |
Ahh WM workshop manual not Wiki being dense again If everything is under control you are not going fast enough.
20th Nov 2017 12:59pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
my drivers side one was aeroplane spotting when I got it , turned out to be one of the mounting rods inside had come adrift , reattached and all was well |
20th Nov 2017 1:17pm |
^ that's what happened to mine.
20th Nov 2017 7:26pm |
Up-date for the above problem.
27th Dec 2017 8:03pm |
Well done, that man!
27th Dec 2017 10:17pm |
If I do have to go in there again I will take pictures, as there is as ever an easy way and a hard way. When you first strip one out you automatically head for the torx screws, all this does is remove the surrounds ect. What you need to go for is the white 90deg turn clips, turn these and the light literally falls apart. If everything is under control you are not going fast enough.
28th Dec 2017 9:53am |
