Home > In Car Electronics (L322) > How do I stop news alerts popping up on DAB?
GGDR
Hello team,
Got one I can't solve (pretty much as per title) - how do I stop news alerts popping in DAB on my MY2011?
I've been through the manual, and turned off all alerts in the SatNav.
But can't find out how to turn this off. Only came in after I had the battery disconnected.
Thanks,
Greg Cheers, Greg
Post #457040 12th Nov 2017 3:07pm
in settings Greg, [number 5]
Post #457043 12th Nov 2017 3:29pm
GGDR
Thanks Stan, yes been in that one...
Pressed CLEAR ALL announcements several times.
And still it pops up..
 Cheers, Greg
Post #457053 12th Nov 2017 4:39pm
At least you can listen to DAB, it’s 💩 here and breaks up all the time. So I’ve resorted to FM which works brilliantly There is nothing that can't be fixed with a hammer😜😜
Post #457077 12th Nov 2017 8:04pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Are they controlled by the "info" button below the volume control?
Post #457100 12th Nov 2017 10:12pm
GGDR
millerj90 - no there's nothing on the info button.
I thought I'd cracked it - I don't use FM but suddenly thought the FM TA etc might be it so I went into the FM settings and turned off TA etc.
But no, it's still popping up.
Big Cry
. Cheers, Greg
Post #458513 25th Nov 2017 5:01pm
miller might be correct..toggle the button and keep an eye on the screen and you should see in the top left some letters popping up..toggle till theres nothing there.. ... - .- -.
Post #458529 25th Nov 2017 7:47pm
GGDR
Hi Stan & millerj90 tried the info button, lots of pressing but absolutely nothing.
. Cheers, Greg
Post #458793 28th Nov 2017 10:02am
make sure its all off in the radio fm mode cos if your fm is linked to dab then the messaging will be as well.
also check pty in fm mode is all deselected.. ... - .- -.
Post #458805 28th Nov 2017 11:59am
