Home > In Car Electronics (L322) > Auxiliary input not working
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
I�m not quite sure if my auxiliary input is working and was wondering if there is a way to test it.
I bought a 3.5mm, male male cable, to plug into my iPhone 7 (using the iPhone headphone adapter) and then plug into the aux in socket.
Chose some music on me Phone and selected aux in on the touch screen, but no sound.
Is it possible to play music this way?
Thought this would be an easy project Laughing
Any help appreciated.
Vehicle is a 2007 TDV8 Vogue with rear seat entertainment 2007 3.6 TDV8
Post #456650 9th Nov 2017 12:22pm
i'd try a different input, maybe a mp3 player? ... - .- -.
Post #456654 9th Nov 2017 12:55pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
ive a splitter in my cubby box the one goes to the bluetooth sender and the other a lead and some times i plug the old ipod in,that works fine, no saved music on my phone but can play the tune-in radio app through the lead on my 6plus iphone with no issues have you checked the volume up i forget at times. _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #456657 9th Nov 2017 12:59pm
mpirie
You should be able to stick a 3.5mm jack cable into the socket, turn the volume up and hear a hum when you grasp the other end of the lead with your fingers, effectively shorting out the input.
If you don't hear the hum, then the socket may be dead.
Mike
Post #456702 9th Nov 2017 7:11pm
supershuttle
There is a bit of chatter (google) about the 3.5mm output not always working correctly (or at all) on iPhone 7s. The check recommended by Mike is a good one if theres a buzz the the car end is OK Geoff
Post #456705 9th Nov 2017 8:23pm
cheezels
Many thanks for the replies.
Seems it could be my iPhone having intermittent problems.
Yesterday no work, today work.
I did however do an update on the phone (bug fixes apparently) so maybe that has solved it.
Thanks again 2007 3.6 TDV8
Post #456721 9th Nov 2017 10:03pm
