![]() | Home > In Car Electronics (L322) > Auxiliary input not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
i'd try a different input, maybe a mp3 player? ... - .- -.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
ive a splitter in my cubby box the one goes to the bluetooth sender and the other a lead and some times i plug the old ipod in,that works fine, no saved music on my phone but can play the tune-in radio app through the lead on my 6plus iphone with no issues have you checked the volume up i forget at times. _____________________________________________________
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 905 ![]() ![]() ![]() |
You should be able to stick a 3.5mm jack cable into the socket, turn the volume up and hear a hum when you grasp the other end of the lead with your fingers, effectively shorting out the input.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
There is a bit of chatter (google) about the 3.5mm output not always working correctly (or at all) on iPhone 7s. The check recommended by Mike is a good one if theres a buzz the the car end is OK Geoff |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Many thanks for the replies.
