Home > Technical (L322) > Fairy lights round Headlights (DRLs - not)
maybe because of the canadian/scandinvian setting.....they should work with just the 'drl standard' setting.. ... - .- -.
Post #456240 5th Nov 2017 2:13pm
bembo449 wrote:
DRL were made law in 2011 so all vehicles have to have them fitted , I guess LR decided to get in early ,
The Law was phrased “all NEW models NOT facelifts must have DRL’s” hence the twinkly lights on the 322, 320 & 319 were just sidelights... Bizarrely JLR saw fit to include DRL’s on the 2014 319 facelift! Perhaps they wanted it to appeal to a “certain demography”??? Whistle
Post #456257 5th Nov 2017 5:47pm
supershuttle
I'm not entering the debate about the whys and wherefores of DRLs and I do understand that the fairy lights are not DRLs. Notwithstanding this I still wanted them to come on with the ignition and the "Auto" light function to work properly - it was actually less complicated that I thought, I just used the IIDTool to turn DRLs on (yes I know !) and I disabled the recently enabled Canadian and Scandinavian options and it would seem that now I have what I want.
Which is the fairy lights on all the time but the rest of the lights operating normally. Thumbs Up Geoff
Post #456342 6th Nov 2017 1:43pm
Sorry Geoff i wasn’t aiming that statement at you sir, rather just for information for the members Thumbs Up
For what its worth, they are turned on on my car simply because when you drive under tree’s at dusk you tend to disappear... Thumbs Up
Post #456393 6th Nov 2017 9:07pm
hopefully still on topic..
craig ,can these fairy lights be made brighter? ... - .- -.
Post #456399 6th Nov 2017 9:39pm
supershuttle
Brighter -- now theres a thought !!
Craig,
No worries mate, I didn't think you were aiming anything at me - until now that is, Censored Rolling with laughter Geoff
Post #456403 6th Nov 2017 10:10pm
No sir...
Well...........
Not with the hardware JLR have used. You could obviously remove the lights, brake them apart and have the LED’s replaced BUT! that would obviously be very expensive...
And maybe replacing the LED’s in the headlamps current configuration may not even be possible?
Post #456404 6th Nov 2017 10:12pm
Thumbs Up ... - .- -.
Post #456425 7th Nov 2017 7:39am
DrRob
Just a quick check....all I do is turn on DRL in the CCF edit and not select any of the country settings to get the fairy lights on all the time with ignition and light switch in auto? I leave switch in auto all the time. Thanks Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545383 27th Feb 2020 8:26pm
Yes DrRob change the DRL to "Standard" Thumbs Up
Post #545396 27th Feb 2020 10:04pm
DrRob
Bow down Bow down Bow down Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545411 28th Feb 2020 7:20am
DrRob
Finally done this. Works a treat. DRL set to Standard as active puts the fairy lights on all time Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579357 11th Jan 2021 6:55pm
