Home > In Car Electronics (L322) > Silent sat nav
AJ Johnny
Silent sat nav
Slowly working through faults on an l322. One is that the sat nav works but with no sound. The mute button appears to do nothing. There is a Parrot blue tooth phone unit fitted which is also problematic so that’s on the list for removal, I add this info in case they may have used the sat nav sound input to the radio amp??
Anyone got any tips for getting sound back on the sat nav?
Post #456166 4th Nov 2017 7:09pm
AJ Johnny
Should have added it’s a standard 2002 screen, not the touch screen.
Post #456167 4th Nov 2017 7:11pm
The sound level of the Satnav is independently variable, could it simply be set to it’s lowest setting?
Post #456182 4th Nov 2017 10:28pm
mpirie
As Niceday says.......when you know the sat nav should be speaking, turn the volume knob up.
Mike
Post #456247 5th Nov 2017 4:24pm
AJ Johnny
Thanks for the replies, RR is back under surgery today so I’ll try this next week. I’m looking forward to a ‘fault’ fixed for free.
Post #456745 10th Nov 2017 8:28am
AJ Johnny
Have the car back and checked the sat nav volume setting. It was at zero so I increased it. Now I hear the radio sound reduce at markers when the sat nav voice should sound e.g. half mile warning, but still no sat nav voice. There is a Parrot blue tooth phone set in the car (which doesn’t work correctly either) was it common or possible that they used the sat nav voice input for the Parrot phone? L322 2002.
Post #457599 17th Nov 2017 1:06pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Could be laryngitis
Post #457602 17th Nov 2017 1:38pm
Weegie
Not clear, are you increasing the volume on the steering wheel control when the sat nav voice should be speaking? John
GAP iiD BT
Post #457603 17th Nov 2017 1:40pm
AJ Johnny
I went to the settings screen and found what I think is a balance control scaled 0 to 12 if I remember correctly, putting it up full causes the radio to quieten when, for example, the sat nav screen shows there’s half a mile to the next turning, then rhe radio rises back to normal volume. It might be reducing the front speakers only? I guess it is quitening the radio to make the sat nav instruction easier to hear. I’m not touching the wheel volume control. Is there another sat nav voice volume setting somewhere?
Post #457759 18th Nov 2017 6:45pm
