Home > Maintenance & Mods (L322) > Fitting new epb shoes
Stew 46
England 2007 Range Rover Vogue SE TDV8 Bonatti Grey
Morning chaps , just fitting new rear lower bushes , disks , pads and epb shoes , is the adjustment on epb the same printable as the disco ? , any advice would be great Thumbs Up many thanks , stew . 07 VSE
Post #455996 3rd Nov 2017 9:19am
kbald
The adjustment is the same as descrided in the disco brake bible, once on and new discs are on too wind the cog wheel until you cant move the wheel then back off about 3 clicks or so. There is a separate bedding in procedure to do which is listed on here if you search where you put it into bedding in mode and pull the epb to stop it about 10 times which adjusts the epb aswell. Current 2007 TDV8 Vogue Buckingham Blue
Post #456033 3rd Nov 2017 4:45pm
something in the wiki re this.. ... - .- -.
Post #456037 3rd Nov 2017 4:56pm
