![]() | Home > Maintenance & Mods (L322) > Fitting new epb shoes |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
The adjustment is the same as descrided in the disco brake bible, once on and new discs are on too wind the cog wheel until you cant move the wheel then back off about 3 clicks or so. There is a separate bedding in procedure to do which is listed on here if you search where you put it into bedding in mode and pull the epb to stop it about 10 times which adjusts the epb aswell. Current 2007 TDV8 Vogue Buckingham Blue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
something in the wiki re this.. ... - .- -.
