Home > Wheels & Tyres > General Grabber AT3 |
RichTDV8 Member Since: 16 May 2010 Location: Surrey Posts: 52 |
David
1st Nov 2017 8:47pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 745 |
Thank you for that Rich!
2nd Nov 2017 10:51am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
I used to run Generals, they will do 60k miles and fantastic off-road - had 3 sets but have Just bought a full set of Cooper 285/50/20's as I couldn't get Generals in this size - they certainly look very capable !
2nd Nov 2017 5:52pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
run cooper LTZs on my disco, also seem very good. There is nothing that can't be fixed with a hammer😜😜
2nd Nov 2017 7:39pm |
Agreed, but unfortunately due to EU rules the LTZ's are no longer available in the UK - they have ceased supply to the UK, only old stock is now being sold until they run out. The replacement is the AT3 Sport which also is available with a higher speed rating, as the LTZ was very low compared to the General Grabbers speed rating. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
2nd Nov 2017 7:47pm |
SABAI4SABAI Member Since: 30 May 2017 Location: Aargau Posts: 13 |
19th Nov 2017 11:10am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
Any news on the snow capability? |
10th Dec 2017 3:20pm |
Tried 2 times ....never as good as a real Winter tire but i could get everywhere i needed...... |
28th Dec 2017 6:14pm |
PH77 Member Since: 14 May 2018 Location: Munich Posts: 4 |
I fancy with the same tire size 275/55r20 AT3s, but worry about the difference on the speedometer. Due to the larger circumfence compared to the original 255/50r20, is there the need to adapt the speedometer? It would indicate a 6% lower speed than it would on the original tires.
14th May 2018 5:57pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1392 |
The 245/45r20 will be way too small compared to the original tyre size.
14th May 2018 6:44pm |
Absolutely correct, I actually meant 275/45r20, which should be almost the same as the original, but still smaller ...
15th May 2018 7:22am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Just this week fitted four AT3's to replace Cooper Zeon's and they are steets ahead on noise and especially wet grip , I knew the Zoen's were poor just not how much. I ran the AT back in Scotland and loved them so I wanted to go back to them but they are not available anymore and thought the AT3 might be too road and winter biased but I'n not so sure now , time will tell butI certainly won't be able to test for their snow ability
16th Jul 2018 9:16am |
