Home > Maintenance & Mods (L322) > Oil change help |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
BUmp Current stable:
28th Oct 2017 10:59pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I think the banjo bolt you are referring to is the feed down from the PCV valve and oil cyclone, two pipes merge into one, and is just a drain back to the sump for the oil that gets separated out from the crank case ventilation. The banjo bolt might have a copper washer either side of the round connector it passes through to help it seal, can't remember without checking microcat or Rave.
29th Oct 2017 1:12am |
Great thanks that’s what I needed to hear - wonder if that contributes to my oil leak... Current stable:
29th Oct 2017 7:14am |
Is this the one ?
29th Oct 2017 7:52am |
It looked like that yes at the back of the sump - the banjo bolt had like a black gritty paste in it - I went 10w40 semi in the end - aside from my noisy tappet it’s very quiet... I tried the Rev to 3 k for 3 mins and off for 30 secs 5 times made no difference.
29th Oct 2017 10:12am |
if you have tapping when warm then it is most likely the vanos units which is common, can't remember your symptoms but vanos is normally start up rattle and tapping when warm.
29th Oct 2017 3:25pm |
Thanks - asked on another forum as well and they were saying that if there’s sludge in the engine then It could be in the tappet(s) and recommend a few short interval oil changes. Think I will have a feel around there Current stable:
29th Oct 2017 9:20pm |
i have used forte advanced flush in mine, others say never flush, but either way i would sort your leak first as yours is getting it's oil changed by leaking
30th Oct 2017 1:06am |
