| | Error Speed control malfunction |  |
 Hi all,
So after some three years of trouble free motoring  I now have an error that I am struggling to find its cause
 The  error code that the iiid is showing is
 P0575-20 Speed control malfunction - speed signal failure
 But the symptoms are bizarre to say the least  first I noticed that my airbag light was on  and after some further digging I noticed that my rear wiper had stopped  and also my rear brake lights were flashing like a Christmas tree, there is a clicking from the centre console  that I am guessing is the DSC as I believe this is its location the clicking matches up with the brake lights flashing.
 I have checked the battery it only 18 months old and shows 12.5 volt all day long and with the engine running I get 13.9 to 14.1  volt so I don't believe it's power related.
 Have also done a battery reset  and cleared any dash errors
 I have checked for water ingress on both sides in the back and generally around the car and all seems dry I was thinking it could be water as it started in the morning after heavy rain that night .
 I have also checked the under seat wiring connectors and the all seem to be ok .
 So what I have noticed is if I start the car and clear the codes, it fails to clear the code but and this is the strange bit,  if I then switch off the car and start it straight back up  the air bag light goes out the rear wiper works and the brake lights stop flashing and I can then clear the code.
 All is then good until I switch the car off again, then it seems to be hit and miss but more often than not the error returns
 Any help with pinning down what this error code is would be most appreciated
