Home > Technical (L322) > Cruise control �jerking�
Stu365
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Santorini Black
First long trip today in my FF. adaptive cruise control, so lots of slowing down and speeding up as I drove down the M1, but I noticed after the road cleared ahead and the car sped up to the selected cruise speed, it would occasionally get to that speed and then do a double jerk, almost as if it was changing into 8th, back to 7th and back up to 8th, or was it accelerating past the speed, slowing down and speeding up again. Non cruise accelerate hard, get to whatever speed and let off the throttle and hold the speed manually there were no issues
Any thoughts?
Post #454842 21st Oct 2017 7:30pm
pld118
Might be in need of software upgrade Stuart.
About �50 if you are paying a main dealer to do it.
4.4TDV8 Hesitant - Software Upgrade LTB00454v2
http://www.fullfatrr.com/forum/topic42006.html?highlight=hesitant
Post #454879 22nd Oct 2017 7:37am
Stu365
Thanks for that, will talk to my independent tomorrow
Post #454896 22nd Oct 2017 10:52am
A1GSS
My 2007 FF did exactly that. hunting between the gears. It was fixed by resetting the tyre rolling diameter in the Nav. Might be worth a try. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #454898 22nd Oct 2017 11:17am
Paul thornton
Which years come with adaptive cruise?
I have it on my new Golf (company car) and it's a really handy feature.
Post #454915 22nd Oct 2017 12:40pm
Stu365
Local independent did the software update for me (�25) and all perfect now, thanks for the advice
Post #455197 24th Oct 2017 9:03pm
GraemeS
Australia
If you have an IIDtool, could you extract your ecm's current s/w level please? Mine has a slight hesitation on CC at 110 kph so I'd like to know if mine's ecm is at your level. However as there are 2 later updates than mine I suspect that mine needs updating.
Post #455224 25th Oct 2017 4:56am
Stu365
Sorry I don�t yet have an iDD tool, that is on the list to get though
Post #455225 25th Oct 2017 5:52am
nino_nino
this is my :
it would be nice if somebody that has had update can check and let us know.
Smile
Post #455285 25th Oct 2017 8:11pm
GraemeS
Australia
Thanks Nino. However I hadn't considered different markets, especially with and without a DPF fitted, so perhaps a futile comparison.
Post #455290 25th Oct 2017 8:34pm
Blair
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Would love the adaptive cruise on mine. Had it on a Golf, and it was blindingly good!
Post #456144 4th Nov 2017 4:44pm
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
Had my '12 4.4 TDV8 for about six months now and I've noticed this last two days that when engaging cruise control right after setting off after startup the car surges as if it can't maintain the desired speed. I've noticed it when setting CC to 30kph and 50kph (haven't been able to test other speeds as I'm always starting out in built up areas).
However, it does this between 5 and 10 times and then the surges stop and the car runs at the set cruise speed normally. It doesn't sound like it's changing gear, just that the car seems to allow the revs to drop a bit then accelerates again to regain cruise speed. We are having quite cold weather here at the moment, 0 degrees or just below. Could it be related to a cold engine? I haven't experienced this problem since I bought the car last June, just yesterday and again today.
Does it sound like the symptoms described by LTB00054v2 or rather a different issue? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #469692 22nd Feb 2018 7:31pm
