![]() | Home > In Car Electronics (L322) > rear camera |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 ![]() ![]() ![]() |
Can't help you with your questions, but hope you get it sorted. I will be watching with interest, as I would love to do this uograde. |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 ![]() ![]() ![]() |
Does it have to be a permanent live or can you not tap into the reverse lights.
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 ![]() ![]() ![]() |
Thanks
When I fitted my reverse camera I managed to get a power cable up the rubber boot as well.
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Cool. Look forward to updates.
Well finally got it hooked up today, and it works!
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 ![]() ![]() ![]() |
I think I'll try this as well. Where did you get the camera from? |
Ebay item number eBay Item No. 142285392981
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
The offset bit seems to be regular occurrence. Regarding the zoom, what angle camera did you use? They can be either 120* or 170* (probably others as well). When I fitted one to my TD6 I used a 170* angle one which was fine. If you have used a 120* one then the angle will be much narrower. Just a thought. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
Hi
I found that a pal/ntsc didn't work. I had to get an ntsc only camera. It showed on the 753 screen but not when I went to normal. John
Right then!
Here are some of the rodding places,
Nice work. Does the screen automatically go to camera view when you select reverse? RR History
