Home > Technical (L322) > 2004 - 2006 Bi-Xenon Help Required |
As most of you know I have a 2004 that's had the face-lifted front end.
10th Jan 2011 8:30pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Dan I'm no help BUT look up our new member mattstevens he has a front end conversion and has had a few light problems so may help. Try dropping Swast (Adam) a message as he's just done the conversion.
10th Jan 2011 8:50pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Hi Rob, thanks for the recommendation! I did have a problem with the new style headlights on my facelift conversion - my car has the 2007 Bi-Xenon NONE adaptive headlights fitted and the issue was that when the diagnostic cover (at the drivers knee) was in the up position (i.e. the cover was closed) it was causing the headlights to drain the cars battery, when the previous owner had the facelift done, who ever did the conversion wired the Bi-Xenon high beam position shutter to the permanent 12+ volts supply from the diagnostic socket so the shutter was permanently energised in the open position. When the weather gets a bit warmer i will re-wire my headlights so that the Bi-Xenon shutter only energises when the high beam switch it turned on until then i just leave the diagnostic cover down so it doesn't drain the battery. And in answer to your second question the main/dipped control is differently separate to the adaptive function. If you PM me your email address i can email you a wiring diagram for a 2002-2006 conversion. Matt Matt |
10th Jan 2011 9:46pm |
Thanks guys - PM's & texts flying all over the place, you're all a great bunch!
10th Jan 2011 10:01pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Dan, have you got photos of your previous 06MY headlights and your new ones?
10th Jan 2011 10:37pm |
Thanks for that Martin,
10th Jan 2011 11:27pm |
Your "old" lights are already Bi-Xenon - "Bi" doesn't refer to two xenon bulbs, but to the two functions of the (single) bulb (dip/main).
10th Jan 2011 11:30pm |
I know it doesnt mean two xenon bulbs... It means that the Xenon is used for both Dipped and Main.
10th Jan 2011 11:43pm |
Josh Wyatt Member Since: 10 Jan 2011 Location: Oxford Posts: 77 |
I understand what you mean Dan. I used to have a '55' TD6 Vogue, and main beam was Xenon and high beam was halogen. I did, however think that Bi-Xenon was only available from either late 2006 or early 2007.
10th Jan 2011 11:57pm |
Ah ok... well that may be how they've been wired on your RR (so the shutter is inactive), however the non-adaptive xenons are fitted with a shutter on the xenon bulb which switches them between dip and main beam in addition to the halogen "fill in" bulb.
10th Jan 2011 11:58pm |
Martin,
11th Jan 2011 12:08am |
OK, well evidently LR have the information regarding headlights wrong on the wiring diagrams and in the workshop manual.
11th Jan 2011 12:09am |
Evidently, either that or the whole of Microcat is wrong, and I have something in front of me that just doesnt exist! |
11th Jan 2011 12:11am |
Here's one of those lights that doesn't exist, note the "Xenon" in the title, not "Bi-Xenon" and that microcat has it as one of the cheapest xenon headlights available....
11th Jan 2011 12:25am |
