Home > Technical (L322) > Heated steering wheel problem !! |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
I know its getting warmer unlike this morning but does anyone have an idea what could be wrong with my heated steering wheel !! when i press the button the red light now only comes on for a split second then goes out and obviously the steering wheel does not heat up !! |
28th Mar 2011 7:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
found this via the search, seems you need to strip and inspect
28th Mar 2011 7:45pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
i can almost 100% say that it will be the actual heating element in the wheel that is faulty, i had the exact same problem and the only way to fix it was to replace the steering wheel with a new one, soon as i did that the heating function worked straight away.
28th Mar 2011 9:52pm |
Jsb Member Since: 24 Nov 2010 Location: Southampton Posts: 78 |
I have a working wheel, removed from my 2007. Let me know if you are interested in it. |
28th Mar 2011 10:19pm |
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 |
same here - thats how I fixed mine - on exchange £100 ish from powerfulUK cheers bogie |
6th Apr 2011 6:01pm |
