Home > Technical (L322) > TD6 3.0 Injector Fault Diagnosis and Repair |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Well thanks for all the help !!
21st Oct 2017 7:18pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2256 |
Good result - afraid I know nothing about chip fat burners but pleased it worked out |
21st Oct 2017 8:01pm |
I know a little bit more than I did , I'm only fixing the tractor for a mate. |
22nd Oct 2017 7:04am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Good to know about the corroded connectors as another possible fix. Normally I would have questioned the injector itself and headed straight for a leak test .
22nd Oct 2017 9:50am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Good find.
22nd Oct 2017 11:37am |
Definitely a common problem, we may still end up replacing the loom. The live data was the key as i could wiggle the wires and watch the values change along with a cough from the engine sometimes.
22nd Oct 2017 1:27pm |
