![]() | Home > Technical (L322) > TD6 3.0 Injector Fault Diagnosis and Repair |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Well thanks for all the help !! |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Good result - afraid I know nothing about chip fat burners but pleased it worked out |
I know a little bit more than I did , I'm only fixing the tractor for a mate. |
Good to know about the corroded connectors as another possible fix. Normally I would have questioned the injector itself and headed straight for a leak test |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Good find.
Definitely a common problem, we may still end up replacing the loom. The live data was the key as i could wiggle the wires and watch the values change along with a cough from the engine sometimes.
