Home > Maintenance & Mods (L322) > diy servicing
cookie42
2005 Range Rover Vogue Td6 Java Black
diy servicing
for those of us who do our own own servicing where do you get your parts from ?
do you use genuine or pattern parts ?
also what do you change ?
many thanks , chris
Post #45468 10th Jan 2011 10:09pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
a "britpart" service set from ebay is sufficient, about £50. fuel,oil,air and pollen filters.
there is a sticky above aswell. 2004 black Vogue TD6
Post #45471 10th Jan 2011 10:17pm
cookie42
yeah i've seen the sticky and have used britpart in the past on my old disco , just not too sure whether its worth paying that bit more for better quality ?
Post #45473 10th Jan 2011 10:25pm
Martin
Site Admin
I'd go for a slightly better quality than Britpart - try a local motor factors for Mann+Hummel or UFI.
Post #45480 10th Jan 2011 10:45pm
Josh Wyatt
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
On all vehicles I tend to use genuine parts as a matter of course. In some cases OEM equivalent parts are good enough. But, for example - An original air filter from the manufacturer does tend to have a greater surface area than aftermarket parts.
My local LR dealer gives me trade discount on all parts I order from them, including service parts which works out well.
Ultimately, it's all about personal preference...but I would only ever fit manufacturer service parts.
I do find the best way to go about it is to have the part numbers in advance.
I am a motor trader, and my business is primarily selling vehicles, but I regularly service and maintain an array of vehicles. I do find taking my trade plates with me to unfamiliar main dealer parts departments and the correct part numbers always gets me good discount. Any local members to me in Oxford are more than welcome to take advantage of this Thumbs Up
Post #45482 10th Jan 2011 10:49pm
ben2012
2005 Range Rover Vogue Td6 Buckingham Blue
I own a defender as well and the chap who looks after my defender won't touch anything from britpart, they don't seem to have the best reputation, like someone else said above either try genuine or 'allmakes' now do a 'premium' or something like that! range which is supposed to be good, they might be worth a try
Post #45485 10th Jan 2011 10:55pm
letsavit2
think my service set had a britpart fuel and air filter and mann fuel filter... Confused
has britpart got a bad rep then, thought they was alright? 2004 black Vogue TD6
Post #45487 10th Jan 2011 11:02pm
Vogue
on other LR forums they are often referred to as Sh!tpart Shocked
however, have used them myself for none critical parts like mudflaps on other LR's, as far as filters are concerned buy genuine and push for a discount
Post #45495 10th Jan 2011 11:30pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Yep - defo none critical parts. I'd rather set my nuts on fire than use their bits on anything linked to steering , suspension or brakes.
I do tend to migrate toward Landrover parts unless they are taking the preverbial.. like £45 for a £5 bearing Power steering pump on my Classic V8, and that was going back probably over 12 years ago. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #45502 11th Jan 2011 12:22am
cookie42
what about the fuel filter , original at £35 or a mahle at £17 ?
http://cgi.ebay.co.uk/Fuel-Filter-RANGEROV...3cb2cdd5db
Post #45510 11th Jan 2011 7:35am
dan_uk_1984
It's worth noting that Land Rover do not make these parts. It's also worth noting that the quality of Genuine parts often leaves a lot to be desired (Especially the BMW parts) - to the extent that some of the 3rd party parts are better quality than genuine because they have been re-designed to not fail within warranty etc.
Post #45535 11th Jan 2011 11:20am
letsavit2
yea, land rover will mostly contract it out and add profit to the costs, although you would expect tighter quality control from them.
Googled Britparts, very mixed reviews to say the least... Laughing
Well i have a mann filter holding in 90quids worth of oil so thats good...
The britpart air filter i handled looked fine and 100% better than the dirty land rover one that came out, cant really see whats going on inside the britpart fuelfilter but seems ok for now, ill just swap it earlier say 6k. 2004 black Vogue TD6
Post #45567 11th Jan 2011 2:18pm
SteveMFr
Site Sponsor
I've worked in and managed repair shops specializing in MB, BMW, Porsche, and LR in the US and in Europe (including main dealers).
You need to do more research. Unless you have too much money.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #45593 11th Jan 2011 6:48pm
letsavit2
SteveM, for us diyer's please do add your view on land rover parts compared to aftermarket. 2004 black Vogue TD6
Post #45600 11th Jan 2011 7:26pm
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
I service my own and I get the oils and filters from Opie Oils with a club discount. Other consumables that are needed I get from whichever supplier that has the best deal and postage rates going at the time.
Post #45624 11th Jan 2011 9:19pm
