Home > In Car Electronics (L322) > towbar electrics for a 2004 td6
bertie1
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
hi have a towbar already fitted but no electrics I only want to tow a small trailer what electrics would be best for a basic set up?
Post #454257 17th Oct 2017 7:29am
fisha
One of the dedicated electronics / wiring kits are likely the best in the long run. They simply plug into the existing system of the car at the rear offside corner area. I found I didn't need to re-program my car after fitting one to my old 2002. The car still recognised when the trailer was attached, disabled the rear parking sensors, displayed when bulbs were out, flashed t he trailer symbol on the dash when indicating etc etc.
I have also fitted the generic kits to cars as well. They work, but its so much more of a faff to strip and join wires, source a 12V feed etc etc ... and at the end of the day still end up with what looks like a bodge-on (even when done neatly) compared to the dedicated kit. V8 or else ...
Post #454292 17th Oct 2017 4:32pm
bertie1
Thanks for reply but im not sure about 7 pin 13 pin 12n and 12 s also not sure of tow bar fitted there seems to be westfalia only ones but will these fit any tow bar?or right connections one but big difference in price . Just need basic electricx only will tow little 4x3 trailer once a month to the tip tbh
Post #454299 17th Oct 2017 5:08pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
For a basic trailer to go to the tip you only need 7 pin 12n single electrics, to take care of lights, indicators and brake lights. Yes the dedicated electrics are expensive but they can be fitted in less than an hour.
I’ve experience of right connections and they can be a bit of a faff, so stick with original you’ll not be sorry... Thumbs Up
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #454318 17th Oct 2017 7:30pm
bertie1
Thanks for reply so i can use the westfalia one ? Cheers for help
Post #454382 18th Oct 2017 9:24am
UK Marine
Absolutely Thumbs Up ______________________________
Simon
Post #454383 18th Oct 2017 9:26am
bertie1
Absolute gentleman thankyou
Post #454385 18th Oct 2017 10:02am
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
Trailer wiring pictures
Here's all the info for any UK/EU/AU trailer setup; US is, err, different (very different!)
http://www.fullfatrr.com/forum/topic36665.html
As you are not adding electric brakes or changing to AU standards its just plug-and-play.
* Add the Siemens TCM module to connector C0380 in the rear fuse panel, (there are at least 3 BMW models that will fit)
* Run the TCM cables to C0499 then through the grommet in the spare wheel space down to the tow bar,
* Wire on your selected trailer socket(s).
bye.
Oh, by-the-way, it is almost impossible to fit or remove C0380 to/from the TCM while it is in place, so make sure they are connected before fitting the TCM in place with its M10 nut.
bye again. 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #456737 10th Nov 2017 6:20am
