Home > Technical (L322) > No Air-Con in front
Mcfly309
No Air-Con in front
Afternoon all,
Last week I noticed the fan stopped working, probably had and I'd not noticed due to music.
All lights on dash work fine, also fan in rear works.
Got a new FSR this morning, and replaced that. Still the same.
Checked fuses under the bonnet: F14, F11.
Checked fuses behind glove box: F15, F16, F62
Still no joy! Big Cry
Any ideas please? I'd like to rule out all possibilities before I even think about hacking the dash up.
Thanks in advance.
Post #453259 7th Oct 2017 1:21pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
My car does the same!!It is intermittend though.Some times the front fan does not work but the back is fine.No FC's!I can force the AC to work by pressing "Max aircon"It will then start to work and if I then switch to Auto it is fine!!If I manually force the fan speed to max it works as well.Another way to get it to work is to manually select face level.
The fact that the rear work tells me it is a sensor!!?
Live readings does not point to a obvious problem.
I will watch your progress with the solving of this!! 2012 TDV8 Vogue SE 4.4
Post #453369 8th Oct 2017 5:45pm
Mcfly309
Air-Con and heating fully restored.
Ended up being the green/yellow wire that goes between the fan and the control box.
So glad it wasn't a dash out job.
Massive thanks to Maltings AGAIN. Bow down
Post #454196 16th Oct 2017 1:55pm
Frans@Yamorna
Please give more details how to go about to locate the said wires!!
Thanks 2012 TDV8 Vogue SE 4.4
Post #454960 22nd Oct 2017 6:42pm
Mcfly309
All I can tell you is, it’s in the area of the FSR.
Post #454976 22nd Oct 2017 8:28pm
