![]() | Home > Technical (L322) > No Air-Con in front |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
My car does the same!!It is intermittend though.Some times the front fan does not work but the back is fine.No FC's!I can force the AC to work by pressing "Max aircon"It will then start to work and if I then switch to Auto it is fine!!If I manually force the fan speed to max it works as well.Another way to get it to work is to manually select face level.
Mcfly309 Member Since: 24 Mar 2016 Location: North Lincolnshire-ish Posts: 76 ![]() ![]() ![]() |
Air-Con and heating fully restored.
Please give more details how to go about to locate the said wires!!
All I can tell you is, it’s in the area of the FSR. |
