Home > Technical (L322) > Diesel Leak |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Noticed a smell of Diesel when I parked up earlier. Seems to be coming from rear of RR
14th Oct 2017 8:42pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Check the FBH (Fuel Burning Heater) pump (Rear Right above upper wishbone) and pipework (from there to tank and to under Left tank cover) .
14th Oct 2017 10:02pm |
Thanks Joe I think you are spot on with your suggestion.
15th Oct 2017 9:51am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
I've got no experience but given my own leaks (onto the diff but from the diff seal) I thought I'd look it up.
15th Oct 2017 10:13am |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
i had the same problem it was the fbh pump the end had rusted off the pump . |
15th Oct 2017 1:29pm |
Thanks guys, Instructions make it look easy.
15th Oct 2017 9:41pm |
You can give yourself a bit more space by getting some jacks under the rear subframe and releasing the subframe mounting bolts and lowering (gently) that side.
15th Oct 2017 10:47pm |
Got the pump changed today. Decided to do it from under the RR. One arm either side of the diff and I managed to get it done.
22nd Oct 2017 8:52pm |
