Home > In Car Electronics (L405) > Look what happened when... |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
Was this only news to me then?
14th Oct 2017 6:36pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
What am I looking at - the rear diff lock or the 11.3mpg ??? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
14th Oct 2017 7:37pm |
The speedo, which is now perfect for low speed work, topping out at 60mph. |
14th Oct 2017 7:48pm |
Oh blimey - missed that 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
14th Oct 2017 7:58pm |
It’s brilliantly simple isn’t it?!
14th Oct 2017 8:04pm |
smudge68 Member Since: 27 Oct 2016 Location: UK Posts: 40 |
Me too, was too focused on the mpg! |
14th Oct 2017 9:00pm |
That’s off road, in low range, for you! |
14th Oct 2017 9:18pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
What times are you doing for 0 - 60 in low range? |
15th Oct 2017 5:56am |
If the mud and wet grass wasn’t enough to stop me from reaching 60, then the gearing certainly would! It would probably top out at about 50!
15th Oct 2017 7:38am |
If moving heavy trailers about or in extreme off road use then Low Box is essential - but then I use the Defender for most of that. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
15th Oct 2017 8:24am |
Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35 |
Having overheated my brakes on HDC coming down a mountain because I didn't engage Low Range, it is definitely not obsolete! |
19th Oct 2017 10:11am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Did some serious off-roading in my Disco a few years ago. Convoy was all Land Rovers except for one Dodge Ram pickup (automatic, huge V8 diesel). Driver kept it in high range during a long, slow climb on a steep mountain road. He overheated the transmission. His giant V8 was fine, but it doesn’t move without a transmission. Nothing in low range had any problems. I like to use low range for any driving where I’m needing a good bit of torque and I’m driving for long periods at a very slow speed. |
28th Oct 2017 9:56pm |
