![]() | Home > In Car Electronics (L405) > Look what happened when... |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Was this only news to me then? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3767 ![]() ![]() |
What am I looking at - the rear diff lock or the 11.3mpg ??? |
The speedo, which is now perfect for low speed work, topping out at 60mph. |
Oh blimey - missed that |
It’s brilliantly simple isn’t it?! |
smudge68 Member Since: 27 Oct 2016 Location: UK Posts: 40 ![]() ![]() ![]() |
Me too, was too focused on the mpg! |
That’s off road, in low range, for you! |
What times are you doing for 0 - 60 in low range? |
If the mud and wet grass wasn’t enough to stop me from reaching 60, then the gearing certainly would! It would probably top out at about 50! |
If moving heavy trailers about or in extreme off road use then Low Box is essential - but then I use the Defender for most of that. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35 ![]() ![]() ![]() |
Having overheated my brakes on HDC coming down a mountain because I didn't engage Low Range, it is definitely not obsolete! |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Did some serious off-roading in my Disco a few years ago. Convoy was all Land Rovers except for one Dodge Ram pickup (automatic, huge V8 diesel). Driver kept it in high range during a long, slow climb on a steep mountain road. He overheated the transmission. His giant V8 was fine, but it doesn’t move without a transmission. Nothing in low range had any problems. I like to use low range for any driving where I’m needing a good bit of torque and I’m driving for long periods at a very slow speed. |
