![]() | Home > Maintenance & Mods (L405) > Add blue |
w8pmc Member Since: 30 Oct 2016 Location: West Lancashire Posts: 229 ![]() ![]() ![]() |
Will try to find the link, but bought 5 bottles (each is nearly 2 litres) of the OEM adblue from a LR parts website. These are the ones presented on the RR videos with the special nozzle specific to the RR. No doubt other variants work fine but I wanted to be sure I had the correct ones to avoid any Warranty issues.
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 ![]() ![]() |
That's what JLR says about it.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
My D4 had an AdBlue tank that supposedly held enough to cover just short of 20,000 miles (in reality just over half of that).
WillyT Member Since: 12 Aug 2016 Location: UK Posts: 90 ![]() ![]() ![]() |
6k sounds about right - same as mine.
Thanks for the confirmation |
Ailamod Member Since: 25 Jul 2017 Location: Scotland Posts: 7 ![]() ![]() |
I am receiving a message now giving me 1,000 miles to refill adblue and I have done 5,100 miles in total.
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1099 ![]() ![]() |
it should do about 9000 miles but do not ignore the warning, most filling stations now have large bottles for about 15 quid, just regard it as an occasional part of refuelling, you will still spend a lot less time at the filling station than if you had a petrol. letters not necessarily in the right order |
@ailamod:
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 408 ![]() ![]() |
My 15.5MY 3.0TDV6 went 9k miles before needing a refill when I was abroad. I managed to find a supply at a tiny garage in the middle of nowhere thank goodness. I had visions of the car going into no start mode and stranding myself, family and boat 1000's of miles from home. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
If stuck, a friendly farmer with a fairly new tractor might help. They usually buy it in bulk. |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1242 ![]() ![]() |
reading thru this thread...
Forget the flash standard fittings; unscrew the lid and fill the reservoir like you would if you were replacing windscreen washer fluid |
Thankyou red |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 ![]() ![]() ![]() |
Presumably Volkswagons dont need adblue |
