Home > Technical (L405) > SDV8 Front Suspension Knocking - LTB00557v8 - Help Needed |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
This thread contains a lot of info -
10th Oct 2017 11:12am |
memzy88 Member Since: 28 Jul 2017 Location: London Posts: 53 |
Thanks Alistair, i sent PM. I also manged to find the full technical bulletin LTB00557v8 in pdf, i like note in regards to the ARC valve saying, "On strong customer complain"... Attaching the old vs new ARC Valve Block with twin damper
10th Oct 2017 11:52am |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
I currently have suspension knock on my 15MY SDV8
10th Oct 2017 2:20pm |
As far as i know new design came in after August 14 cars. MY15 should not have issue with ARC valve. I hope your issue due to less complex parts like bushing, control arm etc |
10th Oct 2017 2:31pm |
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 |
Memzy, just one thought.
11th Oct 2017 9:19pm |
Thanks for the tip Simon, noted. Going in tomorrow morning, will keep you all posted. |
12th Oct 2017 9:27am |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
Hi Just had mine done and touch wood I think it has cured the knock. It took 2-3 attempts at the dealers to get it found and for them to agree to progress with the warranty claim. Try finding a speed hump and approaching on an angle so you go over on a diagonal with one front wheel lifting before the other. This would always create a knock when I needed it to but took me several 1000 miles to establish this. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
14th Oct 2017 4:00pm |
Thanks for the tip CMJ, good to hear some of us managed to sort it out. Lets see how mine will go. I dropped the car on Friday morning and managed to replicate the knocking with master tech in the car who has acknowledged the problem.
16th Oct 2017 9:08am |
Car collected, after extensive tests i can happily say knocking is all gone. Car has been transformed it glides over the bumps and much tighter around the corners.
21st Oct 2017 4:04pm |
Hi Memzy, thanks for the update. I might get in touch for your info before long as Hunters haven't actually fixed my underlying problem just patched it with yet another set of new bushes. Which will wear out.
22nd Oct 2017 7:38am |
Maffya Member Since: 28 Apr 2015 Location: Haddington Posts: 4 |
I am having exactly the same issue and your post and the answers are very interesting. It is just a shame that Pentland Land Rover Edinburgh dismiss all third party commentary as their engineers are all highly trained - yet cannot resolve the noise and handling issues with my car! I have had the Anti roll bar bushes replaced which did make a difference but it is still not right.
7th Nov 2017 8:53pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 |
Can I add myself to the list of SDV8 owners who have this problem and struggling to get the dealership / warranty company to approve the required work.
10th Nov 2017 12:14pm |
Sorry to hear you both are experiencing the pain. Here is the affected VIN range, if your VIN falls into range chances are you have the old design valve block and bullettin applies to your car.
10th Nov 2017 1:31pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1382 |
Maffya, you might like to contact Lloyd Land Rover in Kelso (01573 224345) and see if their workshop foreman, Damien Purves, can attempt a diagnosis. I have no experience of this issue as I have a 322, but my experience there, including Damien being driven in the car with me to diagnose a noise problem, has been positive. I've been a customer there (including the former business Croall Bryson) since 2000, but otherwise have no connection with them. Only Range Rovers since 1988 |
13th Nov 2017 5:20pm |
