Home > Wheels & Tyres > Tired Tyres |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 |
This is now getting ridiculous. The tyres on the wheels that I was looking at in the scrapyard were manufactured in 2002 and 2004.
2nd Oct 2017 12:09pm |
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 |
The early wheels, up to around 2005 use a different nut to the later ones.
2nd Oct 2017 12:43pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
billboard, you have RRS wheels which should have the 23mm shank nuts (as in the 2005 onwards FF)
2nd Oct 2017 12:49pm |
Well, the current tyres are definitely 255/50 R19. The wheels are as shown above and the wheel nuts, which have a 20mm shank, look like this. Is everything wrong?
2nd Oct 2017 4:09pm |
When you put your finger in the wheel, the hole where you removed the bolt, is it bevelled or flat? Porsche 911 (996)
2nd Oct 2017 5:56pm |
Gizze, that would mean taking the wheel off completely, which I was hoping not to have to do.
2nd Oct 2017 7:53pm |
No, just stick you finger in the hole where you took that wheel nut out of.
2nd Oct 2017 8:43pm |
I should just add, the reason it seems a bit strange is Stan is saying your wheels are RRS wheels, your wheel nuts however are early FFRR wheel nuts.
2nd Oct 2017 8:56pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1395 |
Wheel nuts are not designed to locate or centre the wheel on the hub. Wheels are a close tolerance fit via the protrusion of the hub into the centre hole of the wheel. Wheel nuts alone, no matter how torqued up would not be sufficient to hold the wheel central to the hub if it weren't for the protrusion. 2021 D350 Fifty Edition - Carpathian Grey
2nd Oct 2017 10:25pm |
The thing is that these are lug nuts, so, when removed from the wheel, the bolt is still there in the centre of the hole, so there's no way of sticking a finger down.
2nd Oct 2017 10:39pm |
Unnecessary quote removed
2nd Oct 2017 10:45pm |
I never get why I always get "Unnecessary quote removed" when I am replying and it is not the person directly above me but to an earlier poster?
3rd Oct 2017 10:10am |
its a conversation...you dont repeat what someone has said before you reply to him...
3rd Oct 2017 1:09pm |
That's not what I'm saying. You absolutely should always use the correct wheel nuts. The point I was making is that the transfer of the weight of the car happens through the hub/wheel close fit. Correct wheel nuts are essential to bolt the wheel to the face of the hub. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
3rd Oct 2017 1:16pm |
