Home > Wheels & Tyres > Tired Tyres |
Fat Wolfie Member Since: 23 Jul 2017 Location: West Yorkshire Posts: 150 |
I can't help with most of the questions you ask.
29th Sep 2017 7:46am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
I wouldn't be taking my chances with any part worn tyre... |
29th Sep 2017 8:25am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1385 |
I agree, you have no idea of the history of a part worn. I'd stay well clear
29th Sep 2017 8:33am |
Fair enough Mike, neither would I .
29th Sep 2017 8:35am |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
When you buy a used car it comes with part worn tyres does it not?
29th Sep 2017 9:39am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
+1 for part worn tyres.
29th Sep 2017 11:06am |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 |
Well, I do bump over kerbs as gently and at as close to a right angle as possible and just hope for the best. I have usually, on 'normal' cars and on the old Disco, just bought the cheapest tyres from one of the national chains. I only remember once getting tyres that wore out quickly, otherwise they were all fine. The two rear tyres that came on the FFRR are Hifly, which doesn't sound like a posh make, and they have plenty of tread and look OK. I have to say that I don't fancy part worn tyres. Thanks for the info about four wheel alignment. I will look out for that. Old 110 2.3 Petrol ???? - ???? Old 110 200tdi ???? - 2004 1996 Discovery 300tdi 2004 - 2015 met fiery end being welded 2004 JEEP Grand Cherokee 2015 - 2017 2004 L322 Td6 2017 - |
29th Sep 2017 11:49am |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
If you're planning on fitting 18" and bigger tyres I've just fitted a set purely because I had a full set of tyres from another vehicle.
29th Sep 2017 12:06pm |
Thanks,Hamlet, for the forum pointers.
29th Sep 2017 7:40pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Just a point, do the wheels you may buy fit to your car use the same size of wheel nuts you have at present? |
29th Sep 2017 8:35pm |
Well, I've now taken a couple of wheel nuts (I've been calling them lugs) off and measured them.
30th Sep 2017 3:27pm |
I'm still making a meal of this and now preparing to inspect the wheels and tyres on offer.
1st Oct 2017 12:34pm |
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 |
All tyres have the week and year they were made stamped on them....
1st Oct 2017 1:31pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
they are the wrong size ... The RR sport tyres are normally one ratio size smaller than the fullfatrr. For an r19 tyre, the normal tyre size would be 255/55/r19 ... not 255/50/r19. Similarly the R18 size should be 255/60/r18. As for cheap tyres ... I have previous had accelera tyres fitted to a passat and a freelander in years gone by. On camskill.com you can get a 255/60/r18 tyre for £65 ... I would much rather have that newer tyre than an old used higher premium tyre. You can even get a Cooper tyre for £70. Does a £65 accelera tyre have the performance of a £150 pirelli ? . . . no. Is the pirelli double the performance, double the grip, double the wear cause its double the price? absolutely not. Whilst you'll always get the comments of its an RR, ir should have a high level branded tyres on it ... the reality is that under normal, sensible average driving, a tyre such as the accelera will do the job fine. Where it will not show the performance of smething like a pirelli is under harder driving in the wet. You'll reach the limit of grip a little bit earlier with the cheaper tyre ... but you generally need to be pressing on quickly through a sharp corner it to get to those limits. With the wrinklies you say you'll have in the car I expect thats unlikely. I had Accelera Iota's on my 20" alloys on my freelander for a while. They did fine, but in the wet, you could feel them start to slide a littleif you really flung it round a roundabout. It really wasn't a case of 'slightest corner you'll be into the ditch' which I've read on other forums. At the cheap end, I'd personally chose accelera as a make. They've done me well in the past. At the next level up, I'd choose Kumho. I've always been happy with kumho tyres I've bought. At main brand level, I personally cant see past pirelli. Never rated dunlops. Had bad experiences with continental. V8 or else ... |
1st Oct 2017 9:54pm |
