![]() | Home > In Car Electronics (L322) > Navigation MkIV splash screen / roll back |
G62 Member Since: 16 Mar 2017 Location: Bergen Posts: 12 ![]() ![]() ![]() |
Hi Widget,
Widget Member Since: 13 Apr 2017 Location: South East Posts: 2 ![]() ![]() ![]() |
No I'm afraid I'm still driving around in an RR with a BMW screen.
Are you absolutely sure the V32 firmware update disc has the Rangerover splash screen installed, mistakes do happen in "manufacture?" It might be worth asking your supplier. |
I had the same issue a while back. Problem is that system will not update if software version is same as already installed on the satnav computer. I made a new dvd with the latests Range Rover splash screen (the one that mirrors itself) and also changed the version number. This DVD then loaded just fine and updated the splash screen. |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 ![]() ![]() ![]() |
I had same problem rolled it back by loading an earlier version then reloaded v32 again bingo.
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 ![]() ![]() |
I remember when I was playing with the graphics back in the day, changing the colours, adding speed cameras, adding night mode and clouds and that sort of thing.
